Is there a way to set up ConvertX2DVD to have the system shut down when the burn is complete? I could have sworn that "shut down when finished" did this once but I can't get it to work anymore. Thanks
Check under the pulldown menu "action"
There should be an option "shutdown when finished"
What version are you using? -
It's 2.2.3.258. I've been trying it but it doesn't seem to work. I want to have my system shut off when a burn is done so it's not on all day. I was using Apollo Divx to DVD but for some reason I always get an error message with it. I guess it's not compatible with something on my system.
convertx2dvd video bitrate can we fix?
By sumeshkri in forum Video ConversionReplies: 4Last Post: 11th Jun 2010, 16:50 -
different output file size in convertx2dvd
By Iwan2learn in forum Authoring (DVD)Replies: 13Last Post: 13th May 2009, 02:29 -
ConvertX2DVD - menu issue
By urmum in forum Video ConversionReplies: 3Last Post: 31st Jan 2008, 06:59 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 13:48 -
What version of Convertx2dvd to use?
By aat666 in forum Video ConversionReplies: 8Last Post: 26th May 2007, 00:08
