  1. There's about 600gb of Roms/isos that I wanna play on emulators (Sega CD, Sega Saturn, and PSX mostly). If I put these games on a big external USB hard drive, will it affect the speed at which these games play?
    Will it be as fast as if it were on my normal Hard Drive?
    Weltall900@yahoo.com
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I haven't tried the PSX emus, but I get full speed on all the other ones on a USB2 drive. I've used just about all of them, from Nester to KGen to MAME and all between. The only ones I haven't tried are the "Next Gen" ones, like PS2, Gamecube, etc.
  3. Member classfour's Avatar
    The Heartland, United States
    Will USB affect the speed: Likely.
    Will you notice it: Maybe.
    It depends on the quality of the external drive's interface board. If you have a crappy enclosure, it will likely fail. Quality stuff, likely not.
    Will it be as fast as your internal hard drive: I kinda doubt it - but you still may never notice it during play.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  4. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    It may depend on the emu. Some have to be installed whereas some are stand-alone.
    I run SNES, Genesis, TG-16, and NES emulators at work from a thumb drive with no problems.
    PSX and PS2 emulators most likely will not work well on your USB drive...
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
