Hopefully someone can help, I tried the other suggestions I found on the site, but nothing is working. I have avi files that I normally play in Real Player. I was having no trouble at all with them this weekend, but yesterday when I tried to open one, the picture is upside down. I'm not the most computer-literate person, but any help would be awesome. TIA.
Results 1 to 10 of 10
Have you installed any video software or codecs packs lately?
Only one is upside down?
Try installing the latest divx codec.Google is your Friend -
i haven't installed anything since using it this weekend. i think the only thing that changed was a virus scan ran. but i'm not sure how that would mess up the pictures. and no, not just one. even files i watched already and had no problems with were upside down also.
i hadn't tried that, but yes it is in windows media also. i know i have the latest version of that.
I've seen people say things about deleting or updating codecs. how would i need to go about doing that to try and fix it?
The easiest fix is to just install/reinstall the latest divx codec as I pointed out above.
If that doesn't work, then you may need to do some cleanup work. Try a tool such as codecsniper.Google is your Friend -
that worked. thank you so much.
do the codecs update on a regular basis, so i should be watching for that? -
I wouldn't say "regular", but there are updates. For the most part, unless I have trouble playing a particular file, I just leave well enough alone. No reason to "fix" something that is working fine.
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 12:47 -
File conversion problems AVI to Divx
By kaptainm in forum ffmpegX general discussionReplies: 2Last Post: 10th Aug 2008, 19:21 -
Problems When Clicking on an .avi File
By ATAZ in forum ComputerReplies: 5Last Post: 10th Mar 2008, 19:50 -
Having problems compressing AVI file
By nucklhead24 in forum Newbie / General discussionsReplies: 6Last Post: 17th May 2007, 22:42
