I was wondering if anyone started using this DV editing software called VirtualEdit? It will input mpeg2 and DV files and make avi files to be used in its time line then you edit your piece and output at AVI or DV-AVI types 1 or 2. I could not get it to import mov files, it says that directshow does not support mov. I just started to use the free version of it and I am impressed how stable it is and for a basic editor it seems to work. It had a very small foot print on the hard drive too. We actually compared the quality output to Avid Liquid and thought this output was better. I think the paid version gives you more bells and whistles. The software does not seem to pass closed captioning line 21. Any comments from anyone? Thanks.
PS.. I wanted to add that this software can capture in DV from a DV deck via 1394.
Results 1 to 1 of 1
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45 -
Problem importing video into VirtualEdit
By acid_burn in forum EditingReplies: 3Last Post: 23rd May 2007, 10:07
