Results 31 to 60 of 324
Can I connect this unit's S-Video IN port to the S-Video OUT port on a PC graphics card?
Computer out to DVD recorder, via s-video, sure no problem. I do it with my laptop.
I got my aunt one of these from Circuitcity.com for $289.99 plus tax with free shipping (they don't sell them in the stores). I am very pleased with it. The recording quality to the HDD is great.
Thanks,
MC -
It does not appear that the UK model does HD like the USA version.
That sucks for you European folks.Want my help? Ask here! (not via PM!)
Hi.
I have the UK version 3570.
I'm not sure if it's similar to the US version.
It only has an analogue tuner.
You can't record directly to disc.
The remote is rubbish. Rubbery, tiny keys and no eject.
Editing is an awkward and imprecise task.
There seems to be no way to maintain the HDD.
Naming titles is time consuming.
The only good thing I can say about it really, is that the recording quality is very good and it records to dual layer. -
Having owned the 3575, I can say 1. you can record directly to disc 2. the remote may have small keys, but how else are you going to fit the ~47 different buttons onto a remote you can easily fit into your hand, and yes the 3575 does also not have eject on remote. 3. Editing is no more awkward and imprecise than any other DVDR I have used. 4. Title naming is tedious on any DVDR I have used, for easier editing I would think a PC would be the only better method. 5. The US version does not record to Dual Layer discs, so you're one up on us yanks in that respect. I've also read that your model allows videos to be played via the USB port, a feature lacking on the US model.
I knew I should have let you answer this one, my memory's already fading.
I was just guessing on the 47 different buttons too. All I remember is you said it was in the high 40's, and I personally don't remember the remote being particularly rubbery, although I suppose that could be subjective.
Hi.
I was comparing it to Pioneer, Sony, JVC and Panasonic machines, which I have owned, and are all better IMO.
I called Philips support regarding recording directly to DVD and they told me it was not possible, "you must record to the HDD first" was their reply.
Each to his own!
I still have them! They all operate better, and have more options for recording, have better remotes. You name it. As I said the only thing I can find in this machines favour is the recording quality in HQ and SP. Even there though, the Sony and Pioneer are better. Excepting HQ mode, which seems slightly more detailed on the few I've made on the Philips.
I am a sucker for a bargain, but this machine will not record directly to DVD. That's why I called support in the first place, because I couldn't find a way to do it. When you press record, the HDD starts recording. There is no choice between HDD or DVD in the settings, or on the remote, or on the unit.
When editing, the only option for deleting sections seems to be "hide", and it's a pig to hide the last part of a recording because at the end of the recording the machine doesn't pause. It returns you to the edit menu.
Just a couple of reasons why I don't like it.
***By the way, my machine is the UK spec 3570, not the 3575*** -
As I pointed out in my first post, my machine is the UK VERSION 3570.
The reason I mentioned my machine was because on a different post someone mentioned that the UK 3570 was the same/similar as the US 3575. I wasn't trying to confuse anybody. -
Hi all
I have bought recently Philips DVDR3575 and having some setup problems. I read the posts in this forum and used 3575 1st in the line. I have connection like this:
TWC cable outlet to 3575 and to the cable box and to the VCR and finally to the TV all with coax. And A/V connection from cable box to 3575 to be able to record from the box. I have a old TV with only RCA connection so I use VCR kind of RF modulator to switch to TV/DVD.
From the setup I scanned analog/digital channels and analog channels scanned without any problems. However I can't get any digital channels. Moreover it stuck at channel 135. I waited almost 45 but it did nothing.
Here is my question. What am I doing wrong?.
Any feedback is greatly appreciated
thanks -
I have a follow up question
Is this problem go away with Firmware update? Do I need to update my firmware. What kind of problem is this upgrade addressing to?
thanks -
Hi guys.
Two quick questions if anyone can help out.
I'm about to go for the 3595 (bigger brother of the 3575?), and wondered will I be able to record from my SKY box without any hassle? Also, can I pause "mixes" of music and resume where I left off?
(Sorry, I had a longer, more articulate version written but my mouse clicked BACK and I lost the whole thing!)
Thanx for any replies!"I've learned that life is one crushing defeat after another, until you just wish Flanders was dead!" --- Homer J. Simpson -
Thanx. The SKY box is a standalone set-top box, linked to a mini-dish which is located outside the house (duh!) on my wall. SKY charge a monthly subscription to receive their channels. It's currently hooked in vai SCART to my Panny and my telly: should this setup be ok too with the Philips? Not entirely sure what you mean about a line-in: is that the same as a SCART, or are you talking about another cable altogether?
Just want to be sure before I go handing over my cash!
Thx again
TH"I've learned that life is one crushing defeat after another, until you just wish Flanders was dead!" --- Homer J. Simpson -
wabjxo, that sounds right. My TV at the moment is connected to my SKY box through SCART, as is the current DVD recorder, so if I continue that setup with the new one I guess that should be ok. My telly only has the SCART connections, so even if composite would work, I don't think I'd be able to use it.
Anyway, as most everyone connects through SCART here, I don't really think they could sell it if it couldn't be linked up through SCART...
Thx again!"I've learned that life is one crushing defeat after another, until you just wish Flanders was dead!" --- Homer J. Simpson
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3575/76H
By wabjxo in forum DVD & Blu-ray RecordersReplies: 19Last Post: 26th Jan 2011, 18:34 -
My Philips 3576 has stopped dubbing onto DVD-R's
By PhoneMatt in forum DVD & Blu-ray RecordersReplies: 50Last Post: 19th Feb 2009, 15:07 -
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3576
By wabjxo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Sep 2008, 14:43 -
Philips 3576 and 5990 in stock
By victoriabears in forum Newbie / General discussionsReplies: 0Last Post: 26th Aug 2008, 18:23 -
Philips 3575 - Help!!!
By Kansas98 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 30th Jan 2008, 16:44
