DVD-R DL disks are rather expensive if it's simply to make movie backups or home made movies, but they are useful for backups. However, I was wondering if there was such a thing as Rewritable Double Layer Disks? I can't find any, so I'm guessing no, but I could be wrong.
Thank you
Results 1 to 9 of 9
I could be wrong or mis-remembering this, but I thought I saw someone post a pic of a label for these. The catch was that they were very pricey, and only being sold some places in the Far East -- notably Japan. If so, probably won't do us much good.Originally Posted by the_importerWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
Exists? Yes.
Exists for sale? I don't think so, no. Could be wrong, but not seen one.Want my help? Ask here! (not via PM!)
I posted a photo of a DL RW box some time ago. Never found any for delivery, though they were reportedly available in Hong Kong.
I suspect they are near impossible to manufacturer and too expensive to be worth it. Also it's unknown if any burner could use them. The manufacturer was JVC and the one price I saw was about $20US.
JVC never listed them on any of their sites.
Probably outmoded by Blu-ray or other HD discs anyway.
I found the jpeg:
I Googled "dvd-rw dl" and got plenty of hits, but not one linked to an actual source. Can you share just one of the many sources you discovered?Originally Posted by jameshgross
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Useless tech...get BD instead!!!!!!!!
*** Now that you have read me, do some other things. *** -
And play them on machines that few people own?
edit// Mind you, I guess RW/DLs even have less compatibility ... -
Mitsubishi ended development on the discs because reflectivity was less than 10%, and the DVD spec minimum is 18%. Most Mitsubishi media is well above the minimums, too.
Is there such a thing as a reliable DVD Recorder?
By V Bot in forum DVD & Blu-ray RecordersReplies: 22Last Post: 25th Jul 2010, 14:29 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Is there such a thing as a good DVD recorder?
By ibex333 in forum DVD & Blu-ray RecordersReplies: 95Last Post: 25th Oct 2008, 20:00 -
The One Thing That Can Save HD DVD
By cracula in forum DVD & Blu-ray PlayersReplies: 12Last Post: 19th Feb 2008, 13:52 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
