When I tried converting my rm to AVI it created two files and one was a *.dat file. I'm not exactly sure what this file is and I don't know what to open it w, cause none of the programs on my computer will open it. Beyond that I can't play the files that I converted cause all I get is sound in the second file. Does anyone have any idea what my problem is w/ either of these?
Have you tried playing the dat file in WMP? If not, right click and choose "open with" and choose media player. See if it will play then.
i'm tried doing that but it just says "can't play back the file. The format is not supported." Am i possibly missinga codex or something?
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 09:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 01:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
