Hi!
First time posting here and glad to find that there is such a forum as how to restore av.
I have some by a crappy Samsug camcorder captured and already to mpg's rendered video files and I want to make them as clean as possible. So Im using Vegas to render and edit and Dynamic Noise Reduction filter by Mike Crash to clean the noise. So the result is pretty good compared to the input, which was very noisy, but still not completely satisfying. Even after cleaning up the noise, there is still left a net like noise on the video.
So my question is that what is that and how to remove it? You can see the picture I added, especially when you look under the table. How to remove that network like noise?
Regards,
Srivas
That red/blue mist is "chroma noise". I hate it more than any other noise. It is a crosstalk type noise found on analog video tapes.
There are only three ways to remove chroma noise that I'm aware of:
1. The VCR playing a VHS tape must have a line TBC in it. I'm very specific here, so don't ask about other TBCs or other VCRs. This is very effective on the source tapes.
2. VirtualDub Chroma Noise Removal filter. It's about 50% effective, and it can cause other errors if set too high (ghosting, chroma trails, etc).
3. Use an LSI chipset DVD recorder. This is one of the main reasons I suggest JVC DVD recorders to folks.
I also see some blocks. Your bitrate is too low on the Samsung. SP mode uses low bitrate for the resolution, and it might not be sporting the best encoder. Some Samsungs had the horrid Panasonic chips in years past.
Try the MSU Deblock filter and the Static Noise Reduction filters in VirtualDub, to help clean up the block noise.Want my help? Ask here! (not via PM!)
I'm a Premiere user. Don't use Vegas. Make a new post, with "import VirtualDub filters into Vegas?" as the topic. Put it in the Editing or General forum. If that works, and it can be done, come back here to this post for help on using the filters.
Ok.
Actually got it working, VDub filters. Im actually pretty happy that its possible to go even so far, but maybe its possible to go even further?
I opened a new thread for continuation, how to use convolution 3D (in my search I found opinions that this one is the best around for removing noise, so I want the best!), there is also visible the result I got by applying your instructions and playing around with the filters. Thanks
Though, I could not understand how this MSU Deblock filter is working, didnt see any difference in quality.
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 16:51 -
How to remove audio noise?
By Leo48 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2013, 16:09 -
How to remove noise from my HD video
By ITW in forum RestorationReplies: 18Last Post: 26th Jan 2011, 13:24 -
can someone identify what type of noise this is?
By kopmjj in forum RestorationReplies: 7Last Post: 5th May 2010, 18:47 -
how to remove noise from my recorded videos
By harmeetmatta in forum Capturing and VCRReplies: 18Last Post: 6th Apr 2010, 07:45
