Burned an old VCR straight to DVD-R using a VCR/DVDR combo unit. Seemed OK. I then "Finalized" the disc so it's readable in standalone DVD players (and my computer). Now the problem is that when I try to make multiple copies of the disc I get errors with the programs I use.
First I tried DVDShrink. It analyzed the whole DVD (with video preview), got to 97% done and then I got a "Faliure to read D:/"; "data error (cyclic redundancy check)". Then the program shuts down.
Then tried with Nero Recode and had the same problem.
Then I just tried to copy the Video_TS file right to the harddrive to try to dump on a DVDR that way and that didn't work either.
Any ideas?
Results 1 to 21 of 21
The error you describe usually has to do with a problem with the media you're using.
DVDFab HD Decrypter might be able to muscle it's way through the bad spot on the disc in order to get you a copy.
If that doesn't work, you might have to copy the VHS tape again using a different disc. -
I've found that more than one title on a DVDR won't work in DVDShrink. As mentioned....I would just rip it to the computer with DVDDecrypter or ImgBurn.....run it through FixVTS for good measure...then burn them from there.
thanks for the tips guys!
here's an update: first I reburned the VCR to a different brand DVDR. Went from Memorex DVD-R to Fujifilm DVD+R.
Tried DVDShrink again. Same error.
Tried NeroRecode again. Same error.
Tried DVDFab HD Decrypter and didn't get too far. Interface was a bit confusing.
Tried IMGBurn and got the same "cyclic redundancy check: error.
Here's the deal now. The IMGBurn guide says "Firstly make sure your Vob, Ifo and Bup files are in a folder called VIDEO_TS". When I open the DVD on the computer, it does have all the files, but the BUP and IFO files have that Windows icon that means unrecognized format.
I've even added all the files individually in IMGBurn and I'm still getting errors. Arrrgh!
Must be something translated from the VCR/DVDR unit itself. -
Did you run it through FixVTS as was suggested?...
http://webpages.charter.net/bacitup/TheGuides/FixVTS.pdf" Who needs Google, my wife knows everything" -
He hasn't gotten it off of the DVDR yet from what I've read.Originally Posted by t0nee1
How much is on this disc(How many hours)?
What brand of recorder is it? -
Hey Webster,just what or who's post are you editing?
Can't get it off the DVDR. Maybe that's the reason why FixVTS didn't work.
Samsung DVD-VR330. It plays on other machines but I can't rip the thing!!!!!
I copied about 90 min of footage from the VCR tape.
Who knows at this point? My whole goal was to avoid having to make every copy in real time from the actual VCR tape. Of course will all the time I've been wasting on this, I could have made 15 dubs!
I wonder if it's still the fact that Windows doesn't recognize the IFO and BUP files in the "Details" view of the "Video_TS" folder.
I think I'm giving up. Although, it'd be nice to figure out for the future.
Thanks for looking out, guys! -
It needs to be read using a better drive. Software changes will not help.
lordsmurf, you're saying all these problems are stemming from an inferior dvd-drive on my computer?
I think he's talking about your inferior DVDR/VCR combo unit.....
Have you actually tried:Originally Posted by pressthe6
1) DVDDecrypter
ISO READ mode (places an ISO image of the disc on your hard drive)
ISO WRITE mode(burn that ISO image back to a new disc)
2) Just doing a simple "Windows Copy and Paste - Drag and Drop" of the
VIDEO_TS folder to your hard drive.
3) DVDFabDecrypter (different from DVDDecrypter)
I mean....if you had a complete CRAP DVD Recorder like a Cyberhome
or something like that your troubles would not surprise me but Samsung
can't be THAT bad.....in this day and age. I'd love to get my hands on a disc
like that....I love a challenge.....just like i did with my dad's Cybercrap recorder
discs..
That's your problem because both of those brands of dvd media are crappy. You went from using CMC (MEMOREX) to RITEK (FUJIFILM). CMC & RITEK are manufacturers for different brands of dvd media and they are low quality. Try using VERBATIM dvd media. If that doesn't work then as LS mentioned you need a better drive to read your dvd discs.Originally Posted by pressthe6
Yes.Originally Posted by pressthe6
Your inability to read the disc on the computer is most likely related to the drive itself.
This assumes the disc is "good" (it can play fully at the less-than-1x realtime playback on a DVD player). By "good" I mean "good enough to recover". But it's still a pretty crappy burn, all things considered.
You'll need to ISO read, and ISO write, using DVD Decrypter or ImgBurn.
DVD Shrink, Recode, etc ... not the correct software for the task, way off base, left field. Those are transcoders, different than copying discs.
You should fill out your profile, the computer specs, so we know what you have. I have BTC drives, some of the best readers available, for dealing with tough discs. And I mostly use Pioneer burners, some of the best around for burning discs.Want my help? Ask here! (not via PM!)
No... if you read the OP he is trying to GET the info to rip from the disc he recorded on his dvd recorder...... soOriginally Posted by t0nee1Running Fixvts is of no use to him if he can't even get the info off the original disc to his HDDOriginally Posted by t0nee1
I also would say try a diff. PC drive.... but have you tried IsoBuster or IsoBusterPro ??Originally Posted by pressthe6
That bad little boy has done wonders for me in the past with the rare worst possible dvdr's!!!!!!!!! -
DVD Decrypter or ImgBurn = no good
Windows Copy and Paste - Drag and Drop = no good
DVDFabDecrypter = no good
IsoBuster = no good (bad sector)
I even tried to drag and drop using my laptop instead of the desktop and got same error.
Last ditch effort will be to try the Verbatim discs. I'm also going to give this Fuji disc to a guy at work who does this stuff for a living. Let's see how a "pro" does.
Guys, thanks again for the help. Couldn't get this frustrated without cha
I'm also going to try to post my specs..... -
""Samsung DVD-VR330. It plays on other machines but I can't rip the thing!!!!! ...
Gee, maybe the studios should invest in Samsung units to thwart copying their releases?????? SHHHHHHH....
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Handling home made HD recordings
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Mar 2010, 18:03 -
Diffuser home made
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2009, 05:56 -
Home made AVI to FLV
By Eibach in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 15:25 -
Copy home-made DVDs to my computer hard-drive
By CdnMark in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 00:50
![Computer details: Windows XP Media Center Edition Service Pack 2 (bu
2.80 gigahertz Intel Pentium D
200G
1016 Megabytes
Intel(R) 82945G Express Chipset Family [Display ad
TSSTcorp CD/DVDW TS-H552U [CD-ROM drive]
ECS 945GZ/CT-M ECS
Comp](/images/buttons/computer.gif)
