This one baffles me. Every time I encode an MP3 with Adobe Audition, it pads the sample length - it actually resamples the audio during encoding. The anomaly varies, without apparent pattern. The difference seems very slight (less than 4/100ths of a percentile), but as I'm trying to integrate the audio into a video lasting five minutes, even that slight difference becomes frustratingly apparent. It doesn't make a difference what my quality settings are, or whether I choose VBR or CBR. As an example, a recent audio file I had, which clocked in at 15500613 samples, ended up as a CBR MP3 clocking in at 15505871 samples. And yes, I checked the chronological positions of specific peaks near the beginning and end of the two sample specimens and confirmed that the entire sample had indeed been resampled during encoding.
What is going on here? Is this not digital information? How can a dramatic failing like this even exist? If it's bad for a five minute video, it's got to be a staggering deal-breaker for anything longer; the results would be patently unusable.
I guess my questions are: 1) Is there a way of forcing Audition to generate a PROPER MP3? And 2) if not, is there an encoding app out there which is actually capable of doing so?
Thanks.
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 11Last Post: 30th Dec 2014, 05:19 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
How to change sample rate in FFMPEG
By MackanZoor in forum AudioReplies: 5Last Post: 24th Jan 2011, 13:31 -
Video after encoding doubles in length
By lindylex in forum Video ConversionReplies: 3Last Post: 5th Jan 2011, 01:18 -
Program to tell you the combined length of mp3 files?
By branch in forum AudioReplies: 2Last Post: 6th Oct 2010, 21:20
