hi not sure if this is the right forum but need help converting mpg to kvcd
iam using Tmpegenc to convert the mpg. when i load the template all it says is audio will not be included in the file.
do i need codec/s or just a diffrent template??
help plz![]()
Results 1 to 13 of 13
will tmpegenc do that aswell?
when i used to convert to kvcd before it used to do the sound at the same time -
You are likely to hear this anyway, so to get it out of the way, KVCD is a non-standard format and may not work on some, if not many, DVD players. Do you have some overpowering reason to use KVCD? You can put 10 hours of video on a DVD if you want, but I wouldn't watch it.
Just to let you know, KVCD is not that popular around here.
But apparently that version of KVCD templates doesn't have audio, so you will have to encode the audio separately. I would suggest trying ffmpeggui and encode the audio to AC3. It's fairly compact and is DVD compatible. You are using a VCD resolution, so don't expect great quality. But good luck with this. TMPGEnc 'tools' may be able to mux (add) it back with the video. Or if you are making a DVD, you can add the audio during the authoring process.
And welcome to our forums.
thanx,
if its possible i would profer to convert it with sound rather than doing it seperate.
is it just the template iam using that doesnt support the sound ?
and if so does anyone know where i can get a template that will support it ?
thanx agen -
thanx for the help figured it out
heres how to do it incase anyone else runs into this problem
you probably got the right twmplates m8, what you do is follow, the guides as you would normally to encode. but at the last box you uncheck the encode immediately box, then you check the system audio/video option and you WILL get both encoded. Theres a detailed guide here m8
http://www.weethet.nl/english/video_kvcd_intro.php should help you out -
Yes.Originally Posted by G33333
No. As redwudz said, KVCD isn't very popular around here. If you are insistent about using it, you can go to http://www.kvcd.net and consider paying to join the website. If you pay, they have various things you can download, but ONLY if you pay to join. Not only do many of us thing the KVCD format is crap, we have a problem with them making you pay to get help and download stuff, but that's how they run things in KVCDland.Originally Posted by G33333 -
Paying for help isn't the issue as much as KVCD is a crappy non-format "format" created by an egotist to butcher the hell out of video to squeeze it onto a CD or less DVDs. It's ridiculous. Teaching people how to make video worse is the anti-thesis of this very site.
You're better off doing pretty much anything else.
The only thing worse than a KVCD is Youtube, but even those Youtube videos handle color better. Flash is more robust than a compressed-to-hell MPEG file.Want my help? Ask here! (not via PM!)
Just some notes:
--> 352x240/288 is acceptable (IMO) only if the the screen size of
your TV-set is 29'' or less;
--> drop the wizards, because they usually prevent the user from
actually learning something about what they are (not) doing;
--> if you simply set TMPGEnc to encode in CQ=70 with max bitrate = 2000 kbps
then you won't need to use the kVCD template at all ---
kwag's quantization matrix can reduce the size of your new MPEG-1 file,
but it also will make its quality even lower. You have been warned.
Hope this helps.
So true Midzuki, I encoded a few movies for a friend or 2, and went kvcd because I was low on dvd's at the time, and only because they had 25" and 27" t.v. sets. Other than those factors, the quality is nothing to brag about.--> 352x240/288 is acceptable (IMO) only if the the screen size of
your TV-set is 29'' or less; -
kvcd? how about svcd instead that would be more decent to me
a vcd with 1800k of bitrate now that's ridiculous
mpg1 is one ugly codec for real ....it helped in 1998 lol but c'mon*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
You know, lordsmurf, sometimes I get really annoyed with you, and sometimes I think you show a lot of common sense and even genius. I'm pretty sure you feel the same about me (well, the annoyed part, anyway). But I couldn't agree more with that statement. So whenever these KVCD threads pop up, or the ones about "How can I fit 10 hours on a DVD", or "I want to put 5 DVDs onto a single layer DVDR", or even "I have a crappy YouTube video I want to make look good for DVD", I just want to yell, "Get the f**k outta here!" Pandering to these people only lowers the reputation of this site.Originally Posted by lordsmurf
People that want to make KVCD stuff should go ask the idiots at KVCD.net. And don't forget to pay your registration fee. -
manono-sama wrote:
Come on, dear Master. There is no need to be so harsh ---"Get the f**k outta here!"
especially if we consider that it's Christmas time
IMHO, saying
should be sufficient"We're tired!
This type of question has been asked and answered too many times!
USE google TO SCAN THE DAMN SITE
Speaking of "Christmas time", happy MMVIII (to everyone whose name
is not listed on my Black Book, bien entendu)
--- even though the New Year's Day should be around March 21, and
even though nothing changes on New Year's Day.
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08 -
Xvid to KVCD
By mjaeson in forum Video ConversionReplies: 8Last Post: 25th May 2007, 20:05
