  1. I keep collecting info and links (on my web site) about how to capture SVCD standard 'on the fly' with MMC 7.5 ... I think we are nearly there!
    Check my homepage for some new links
    your pal,
    Stinky
  2. first, using the CBR is more likely to keep the ATI MPEGs within SVCD bounds. it still varies a few hundred kbps, but nowhere near the spikes the VBR has. i use around 2.24Mbps CBR for most applications. it goes between 40-48 min on 80min CDR for most captures.
    off topic question - i'm considering the switch to 7.5, and i know you're a big proponent, but i'm using the computer as my primary tv for a while. my friend says he has problems with full-screen file playback, that you can see the top few lines on the desktop, which i would find pretty annoying. i know 7.1 doesn't do this, but does 7.5 with a 128 Pro?
  3. I kept my SVCD templates to CBR at 2.3
    2.3 CBR seems to be the most common 'suggested standard'
    I'm just excited that I found a way to make them Nero compliant - that makes my life so much easier
    as for the switch to 7.5 I get a lot of email from people asking me about the install - not that I'm an expert at all - I had a very simple install - but to answer your question - on my Radeon I don't have the full-screen problem. When I go to full-screen it looks just right.
    I installed 7.5 right on top of 7.1 and didnt have any problems - some people have had problems with 7.5 but once they uninstall it - follow the top part of this guide on how to clean out all previous MMC installs (http://www.vcdhelp.com/ATI_AIW_Guide.htm) and then reinstall 7.5 99% of the time their problems go away.
    your pal,
    Stinky
