What is the best way to go from a large MJPEG video at 1280x720 to something smaller in size, not resolution to be able to post on the web? Can I just use one program, or will I need to use multiple programs and steps to reach a good quality video for the internet.
I believe I'm looking around 0.3-0.5 MB/sec for 1280x720 video.
Should I use wmv, xvid, h264, x264, etc?
0.5 Mb/s is too low for 1280x720, even if you use AVC/H264.
WMV3 or XviD would require around 5000 kbps for getting acceptable
quality @ 1280x720. Currently videos for the web are not practical
when above 640x480 (IMO at least).
HD 1280x720 stuff on gametrailers is around 0.4-0.5 MB/sec. How can I make it like those videos?
I can see that being possible for 720x400 res, but 1280x720 is gonna have artifacts at 500B.
So it was a misunderstanding... apologies =^.^=;
you were talking about Megabytes per second,
I was thinking about megabits per second --- not
the same thing of course. Anyway, I have just downloaded
and watched a 1280x720 demo video from gametrailerzdotcom ---
it is 2 min 20 sec long, 55.4 MB big, and the average bitrate is
382 kB/s == 3050 kbps. Naturally, it plays back in slight slow-motion
on my low-powered Pentium IV, and the audio cannot be kept in
sync with the video. Time for me to get a hardware upgrade,
I'm afraid.
So what is the best program /codec to use to make it look like gametrailer's videos?
For WMV3: Windows Media Encoder or WMVmuxer
( you can use VirtualDub + the WMV3 VfW codecs if you prefer the AVI container ^_^ )
For AVC: x264 ( long and steep learning curve ^.^;; ) or encavc & mp4muxer
(apparently easier)
How do I know if the source is 30fps or 60 or whatever eventhough my capture devices captures at 59.97 fps?
Resizing and joining two avi files and keeping file size down
By wayc00lio in forum Newbie / General discussionsReplies: 5Last Post: 16th Feb 2011, 11:18 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 11:01 -
re-encoding vid file for smaller size but keeping same format?
By WidowMaker in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 14:56 -
[help] small size good quality
By las7h0p3 in forum Video ConversionReplies: 1Last Post: 6th Nov 2008, 09:27
