im using VSO Convert X to DVD program
when i put a Video file in the program i can change the size i want for the output file..
if i convert a 700MB AVI to a 700MB DVD it lost quality?
t
thanks
Assuming this is a standard length movie (90 minutes), you might get two files to a DVD. If it is a longer film (100 minutes+) then I would put only one to a disc.
If you try to fit a movie into a 700MB DVD structure, it will look awful.Read my blog here.
i converted a 90min avi (700MB) to 2GB DVD, because i changed the size of the output video from 4 GB to 2 GB..
do you think it lost quality? -
Short answer, yes. But it will depend on the quality of the source. Each conversion reduces quality. The only way to know for sure is to also create a 4Gb version, compare the two, and then decide which of the two work best for you.
Google is your Friend
i have a question. DVD to a single avi/mpg.
By adan_4u in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 23:22 -
AVI to DVD Question
By Cyberian75 in forum Video ConversionReplies: 2Last Post: 8th Jul 2010, 19:06 -
AVI to DVD audio/video question
By Iconoclast_211 in forum Newbie / General discussionsReplies: 3Last Post: 25th Mar 2009, 12:00 -
I have a question about burning avi files to dvd...
By amcardwell in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2008, 15:07 -
AVI ---> DVD question
By arcticmoonshadow in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2008, 21:40
