Hi im new on videohelp and need help with my tevion dvd 7072, i stupidly changed the video output to component only which my tv doesn't seem to support, and wondered if anyone could guide me into the setup menu to change the video output. Also would someone be able to tell me the component spec for this dvd player
Regards Rob
If you now only have a component output, it will be appearing on the red green and blue phono outputs. As you don't have the matching connections on your TV (which most European spec TVs don't have), you'll need to find a way of displaying it. I assume your TV does have standard composite inputs (red and white for audio, yellow for video). Set your TV to composite input and connect from one of the red, green blue sockets to the yellow phono. You will get a picture even if the colours are completely wrong. At least then you will be able to nagivate through the menus to change the setting to something your TV can display. You may need to experiment to see which colour gives the most readable display.
Tevion TDR930 DVD Recorder Problem
By markw6796 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Mar 2009, 16:40 -
Tevion TDVD08 DVD Player - Picture problem when 5.1 ch setting used
By alfredspacey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Jun 2008, 01:03 -
Problem with Tevion HDMI DVD player
By Buna3000 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Oct 2007, 11:43 -
multiregion hack for tevion 7072 dvd player wanted
By fatboy1978 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 22nd Aug 2007, 01:52 -
Tevion 7072 (Adi) does it play Divx?
By bogstandard in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Jul 2007, 11:42
