    Nov 2002
    How can you normalize ac3 audio? I've recently came across some divx clips but the sound is so low you can barely hear it with the speakers cranked wide open.
    If you are playing on your computer/htpc then use ac3filter as ac3 decoder and boost the volume in the config->gain.
    Nov 2007
    You could also demux it and adjust the level of the audio. AC3Machine a frontend for BeSweet has an Auto Find Maximum Gain switch. It also has a manual gain db setting. Good luck.
    *off topic*
    Baldrick, your avatar pic makes me grin everytime I see it. Love the series.
    Cheers,
    Rick
