I'm sure the gurus have a simple answer but I just could not overcome jerkiness/freeze/dropped frames after ripping a dvd with DVD Decrypter and saving directly as a ISO file for further authoring/burning.
What I discovered was if I ripped a commercial DVD and saved to hard disc as VOB/IFO files in normal TS folders etc AND THEN authored with DVD Shrink 3.2, I had no problem and could burn perfect DVD discs. Similarly, the ISO files I could play back direct from my hard drive using 3 different players with no problems....so I'm estatic.
Correct me if I'm wrong but this is the way you would have to do it anyway if you want to author sub-titles?
Good luck and good ripping to all.
Bizarre Premiere Pro bug that I can't find a workaround for
By Asterra in forum Newbie / General discussionsReplies: 8Last Post: 28th Jun 2011, 21:46 -
Whats the craziest workaround you used to capture a purchased online video?
By yoda313 in forum Off topicReplies: 4Last Post: 25th Mar 2011, 20:59 -
Workaround for MaestroSBT's R2L-issue
By Midzuki in forum SubtitleReplies: 0Last Post: 20th Apr 2009, 12:32 -
HDMI Workaround or hack
By Scooter_NJ in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Mar 2008, 22:11 -
Possible display bug - minor, with workaround
By Neil Herber in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Sep 2007, 19:00
