I want to backup my AVCHD video files. I want to put them on DVD-R discs (sets). I have NERO 8 BackitUp. What is the best method and procedure to get this done right?Of course, if you use one program, it (or its format) may be obsolete in 9 years from now and you can't retrieve the data/video when you want it again. Soooo??????? I don't want to rely on external drives to make backups of my home movies. Maybe, Double Layer 2.4X-6X 8.5GB DVD+R DL Media, w/zero (0) compression ??????
Thanks.
Owner: Panasonic HDC-SD1 camcorder w/8gb SDHC card (AVCHD)
Comments please?
Thanks.Owner: Panasonic HDC-SD1 camcorder w/8gb SDHC card (AVCHD) -
Yeah. Read the forum rules and wait at least 24 hours before bumping your own post. It's only polite.Originally Posted by AVCHD
Most reliable is likely to be an external HDD. Likely to have a longer shelf-life than most DL DVDs, and is much cheaper per GB for storage.
If you must use DL discs, use only Singapore manufactured Verbatim +R DL discs. If you are going to use anything esle you might as well just delete your files instead for all the good it will do. Burn with Imgburn in Build mode. Nero is a poor DL burning application.Read my blog here.
Split your files into ~4 GB chunks and burn them in "DVD-ROM (ISO)" format in Nero Burning ROM. The format will be readable (aside from media failure) for the foreseeable future.
Can I use this WD TV devise to play AVCHD video files?
By jbitakis in forum Media Center PC / MediaCentersReplies: 23Last Post: 16th Sep 2013, 14:05 -
Separate AVCHD video files for burning on DVD
By csh in forum Authoring (Blu-ray)Replies: 5Last Post: 13th Jan 2012, 01:01 -
problem with smooth video VOB files from AVCHD
By earlimel in forum Authoring (DVD)Replies: 6Last Post: 16th May 2011, 09:34 -
Most practical method to convert from ProRes to AVCHD
By mikeveli20 in forum MacReplies: 0Last Post: 12th Mar 2011, 15:21 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 15:45
