    Jan 2007
    I use to use DVD2ONE, but it ran out and dont have the 45 dollars today. Is there a program that would fit into its area?
    Is DVDforger the best for a subsitute for this program?
    USA
    It looks like the freeware DVD Shrink and DVDFab Decrypter would do about the same as DVD2ONE if you need to back up a existing DVD to a smaller size.
    DVDForger is a re-encoder that may take a while, while Shrink is a transcoder and very quick. But if you have to reduce the size quite a bit, a re-encoder may be a better choice for preserving quality. DVD Rebuilder may be similar in that it re-encodes a DVD.
    Jan 2007
    I downloaded DVD Fab and it doesnt merge.
    Apr 2004
    Miskatonic U
    Did you download the demo of DVDFab, or the freeware ripper DVDFab HD Decrypter ? They are not the same thing.
    Read my blog here.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    dvd shrink can merge but you will lose the menus.
    Jan 2007
    I downloaded DVD Fab Decrypter, I didnt see DVD Fab
    Jan 2007
    I need something for AVI?
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    If you want to convert AVI files to dvd you don't have to join them. Just add all avis in a dvd converter tool like convertxtodvd, dvd flick and convert to one dvd.
