Just downloaded season 3 of ghost hunters. Its on AVI format 19 45 minute clips. What is the best way to put them on DVD?
Should I hook like 6 together into one and then use Image Burn to put it on DVD or is there a easy way?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
			Closed Thread
	19 X 45 = 865 minutes or 14 hours. It depends on their quality and the quality you want on the DVD. I would be tempted to go with 1/2 D1 format and put about 4 hours per DVD. That would give you about five episodes per disc. You could stretch that to six episodes and 4.5 hours easy enough. For info on the DVD format and 1/2 D1, look to 'WHAT IS' DVD to the upper left on this page.
 If you put the running time of five or six episodes into a bitrate calculator, that will tell you the bitrate needed. I would also use AC3 or other fairly compact and DVD compliant audio to maximize the video bitrate. Using a running time of 4.5 hours for six episodes, I come up with about 2000Kbps bitrate, about right for 1/2 D1. You could drop it down to VCD bitrate of 1150Kbps if your source quality is lower and put about twice that many on a DVD.
 Bitrate calculators here: https://www.videohelp.com/tools/sections/bitrate-calculators
 How you encode it to MPEG-2 or MPEG-1 is up to you. I usually use a stand alone MPEG encoder and DVD authoring program. You can find both as freeware. Or you could use a all-in-one converter that may work for you. No matter which way, you need to know what bitrate it will use so you, or it can determine the filesize and quality.
 Of course if you have a Divx set top player and the episodes are Divx compliant, you could save a lot of time and energy by just burning them to a DVD data disc with ImgBurn.
  Help/Advice Converting .AVI Divx Files To ...By MourningStar in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 17:18
  Advice please for a newbie - AVI to different format with subtitlesBy brodders20 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jul 2009, 16:10
  Advice on converting TV recorded .TS to AVI or H.264By doveman in forum Video ConversionReplies: 8Last Post: 22nd Apr 2009, 10:06
  What do you guys think of hard drives for permanent storage? Need adviceBy dafoe in forum ComputerReplies: 26Last Post: 3rd Nov 2008, 13:36
  AVI to DVD looks all pixeled. Advice?By tmac2085 in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2007, 21:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
