I am converting an .flv file into another format... which format do you recommend that will give me the most quality?
thank you
You can't really improve the quality by converting to another format. Garbage In Garbage Out.
Why do you need to convert? -
Just to add.. What do you want to play it back on? If it's a DVD set top player, encoding to MPEG-2 would be a good choice. If you have a Divx set top player, you could use that format. But if you only want to play it back on a computer, then I would leave it as .flv.
With encoding, the bitrate you choose is what usually sets the quality. If the file is short, less than a hour, you could use about 9500Kbps for a MPEG-2 bitrate to get the best quality. Or use a bitrate calculator to set a bitrate to fit your media size.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
