Hi Guys,
I have been converting all the avi files using tmpgenc to mpg formats using the NTSC template with the software.Now it converts without any problems but when I want to burn them in Nero 5.5 using the VCD format the Burn button is not available for to complete the burn process. Can anybody help me on this matter.
Thanks in advance.
Sameer
If you open the VideoCD format and drop and drag an mpeg file into the normal box, the burn button should appear. If not press "file" then "compilation info" and you should have the burn button tab to your right. If this too doesn't work, then I presume your Nero software is faulty. Try reloading it.
Thanks Aldus4...
But I uninstalled Nero 5.5 & installed EZ CD Creator Platinum & it works fine.
Thanks for your support.
Converting AVI to other format.
By abozny in forum ffmpegX general discussionReplies: 3Last Post: 11th Apr 2012, 08:46 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 06:19 -
Problem converting avi to dvd format with Avi2dvd
By bgart13 in forum Video ConversionReplies: 0Last Post: 13th Apr 2008, 17:27 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27
