    Nov 2007
    Anguilla
    Can anybody help PLEASE!
    I need to re-enter the region code on my Coby 224 DVD however the remote is broken and I am using a universal one. The universal one does not have the buttons TITLE or SETUP as needed in the advise given on this in previous postings.
    Anybody help with how I can do this - I am a real techno-phobic so it needs to be simple!
    Thanks in advance for your help.
    USA
    Have you looked for a direct replacement remote on Ebay? If the universal remote won't work and you can't repair the old remote, you may be out of luck.
    You might ask the question on the CDFreaks forum: http://www.cdfreaks.com/ Or maybe the AVS forum: http://avsforum.com/
