Can you make any assumptions on the burn of a dvd by looking at the dye on the disks? I have a few that exhibit diffrent shades of color in rings on the disc. The inside is apparently more saturated with dye and it diminishes in steps as you move outside. I am thinking this is due to different recording speeds, as seemingly no matter what I do I can't get a consistent writing rate throughout. Let me know your insights.
What brand and type of DVD media are you using? If you are not using good quality media, the dye may not be uniformly applied. You can also look to this site for DVD dye info: http://www.digitalfaq.com/media/index.htm
Particularly look to the part about Z-CLV burning modes in 'Advanced Concepts....' and that might answer your question.
What I look for in the dye most times is blotches, unevenness, and odd gaps between the burned tracks. -
Verbatim 16x DVD+R. Two different burns of the same image will offer two different dye patterns.
Based on past forum posts, I suspect you may have hit on it with the first post. Say, if you burned at 16X, but the burner started at 4X and ramped up as the disc burned (i.e. burns faster the closer it gets to the outside), it may have produced the rings as described. Otherwise, there may be issues with the media - but I kinda doubt that if you're using Verbatims.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 12:40 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 21:16 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 14:58 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 10:24
