Hi
I am using DVD Lab Pro to make a DVD of a home movie.
I've used it before with great success, but this one is driving me mad.
I set the chapters, and then index them so the mark above them turns to a green diamond, then go through the motion menu process, and set the menus, i make sure each button on the menus is linked correctly to the relevant chapter and burn it.
When i play it, only the first couple of chapters work, when i try and play the others the DVD just stops and returns to the home page.
Any ideas whats wrong ?
Results 1 to 10 of 10
A couple of things I would do, regardless of this problem, and that probably won't fix your problem, but . .
1. Frame Index before you place your chapter marks. The point of frame indexing is to give greater accuracy to chapter placement. Index after you place chapters gains you nothing.
2. Never burn without testing from your HDD first. Use PowerDVD or WinDVD, and use the keyboard, not the mouse.
With your particular problem,
1. What was the source ?
2. What was the source container (VOB, mpg, or elementary streams)
3. If the answer to 2 wasn't elementary streams, did you demux in DLP ?Read my blog here.
Are you burning to SL or DL discs
Is it possible the other buttons point to a section on Layer-2, but the burn did not go correctly?
Regards,
George -
i might add a 1a) to tinker's list. sometimes the mpeg video stream needs to have the timecode corrected. so add tools/rewrite GOP timecode to the list.
Hi all
Still having trouble with the above, and i am losing the will to live with this.
Heres a quick run down of what i have done.
1. Recorded some VHS clips and Cine film onto my DVD recorder through the TV and a Camcorder, this is all ok.
2. Burnt all 38 clips in total onto a DVD in the DVD recorder.
3. Used DVD decrypter to transfer this movie onto the PC into VOB files.
4. Imported VOB files into DVD Lab Pro, this is where the trouble is, when i do all the menus etc, set the chapters etc (in the order above) one of two things is happening -
If i Demux on import then i get an MPV file and an AC3 files, if i combine these into the movie, set chapters and burn then i get the chapter breaks ok but now the audio is out of synch.
If i dont demux and make a joinedVOB file then the audio is fine but the chapter breaks dont work and i just get one long 2hr movie with no chapters.
Whats going wrong ??????????? -
First of all I do not understand why you use Decrypter to transfer files on hard drive.
If the DVD is your creation than there is no protection so you can just insert DVD into the player click on OPEN and copy Video-Ts folder (with all the video files in it) to your hard drive.
Once done play that folder in your software player to see if it works OK (video + audio in sync).
Are you running Vista?
Check if you have latest version of DVD Lab.
Demux on import
Frame Index
Set Chapters
If your original is DVD compliant Mpeg2, it should work.
What are the specs after demux for audio and video in DVD lab asset bin? -
Even for non-protected discs, DVD Decrypter is a hand tool to use to transfer the content to your HDD.
I have never had audio sync problems from muxing with DLP.
I never use anything but elementary streams.
What I would do to test where the problem is occurring is to load the mpv and AC3 files into Media Player Classic and check the sync before authoring.Read my blog here.
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 17:19 -
DVD-Lab - creating chapters
By Kimosabe in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2008, 08:41 -
dvd-lab: import chapters
By cL0N31 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2008, 20:32 -
DVD Lab Pro trouble with background and importing
By stantheman1976 in forum Authoring (DVD)Replies: 13Last Post: 3rd Apr 2008, 08:41 -
DVD Lab Pro chapters question
By jesterhud in forum Authoring (DVD)Replies: 9Last Post: 23rd Aug 2007, 18:06
