There is an issue with Pioneer burners that you can't update the firmware by regular means if you have Intel Application Accelerator installed. You will get an error message saying there's a disc in the drive even if there isn't. Uninstalling this is not an option because my raid 0 drives require this and I will lose everything on the drives if I get rid of it.
So I'm left with using the program DVR Flash. When I dbl click on it a DOS window opens up and says:
C:\Documents and Settings\Joshua Denton\Desktop\New Folder\win32\DVRFlash.exe
After that it says a device parameter was not given and lists my DVR drive and information. It tells me at the bottom to run DVRFlash again from the command prompt using one of the device(s) listed above as first parameter.
I don't know anything about DOS commands. Can someone instruct me on what to do.
go to the PIONEER FORUM at Cdfreaks.com they have a sticky thread on how to flash using DVR FLASH. you'll be able to get more help there.
read one of the threads there and firgured out what to do
thanks for pointing me in the right direction
Pioneer DVR 545 HX-S update firmware
By josef2010 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 17th Nov 2008, 12:25 -
Help, firmware update problem of Pioneer DVR 630HS
By stepw in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Oct 2008, 12:05 -
Pioneer DVR-K06RS firmware update for Intel Mac?
By narquespamley in forum MacReplies: 1Last Post: 21st Apr 2008, 10:51 -
FYI:Pioneer DVR-115D Firmware Update
By pepegot1 in forum DVD & Blu-ray WritersReplies: 3Last Post: 31st Jan 2008, 13:50 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 09:48
