    Oct 2007
    Iran, Islamic Republic of
    hi,
    how can i find out a .sub/idx subtitle fps?
    thx.
    LOVE IS A FORCE OF NATURE,but i prefer it my way!
  2. As far as I know, you can't, unless someone added the information inside the IDX or in an accompanying text file. About all you can do is to play it along with the movie. If they're in synch, it's in the same format as the movie. If not, it isn't. It's easy enough to change an IDX/SUB file from PAL (25fps) to NTSC (23.976 or 29.97fps) and vice-versa, so there shouldn't be any problem anyway.
