I have a complete VIDEO_TS folder and also Nero Ultra 7 on my PC.
I cannot find where in Nero I can put this VIDEO_TS Folder so that I'll end up with a DL DVD which will play on a DVD Player. Nero indicates to use the DVD-Compilation, but I cannot find that.
I also have a copy of Nero v8114 Ultra but haven't installed it yet.
On my Mac, it's easy. I would just drag the folder into POPCORN and burn it. Nero is not intuitive.
Help !!
THANK YOU.
Hi
Load "Nero SmartStart / Nero Burning Rom / New Compilation DVD / DVD-Video (third icon down)" and change label (using the fan) - Then click the "New" button (top right) and finally drag-drop the directory VIDEO_TS from the far right-panel to the second left-panel .
- The correct DVD structure will be created by Nero. Then click the (above) icon "Burns the current compilation"
and chose speed and finally hit the (top right) button "Burn" .
regards Pol -
On PC, you use ImgBurn to burn it.On my Mac, it's easy. I would just drag the folder into POPCORN and burn it
/Mats -
Mats.hogberg is correct. Nero produces a playable DVD if you use a single layer media, although it won't be completely compliant with the DVD standard. However, I have seen a number of reports saying Nero does not produce acceptable transitions between layers when dual layer media is used. ImgBurn is reported to burn both single and double layer media correctly. Given the cost of good DL media, I'd use ImgBurn (free software) instead.
And then - why use something you have to pay for, when there is something you can have for free, that does it better?
Originally Posted by mats.hogberg
Awesome. Not intuitive, but it worked. Why is navigating through Mac software simpler and makes more sense ? -
Because Mac users are spoiled with nice, cuddly, friendly software, while the archetype PC user is a gearhead used to dull no frills quirky software (preferably a command line tool without GUI) that just does what it's supposed to (once you've figured it out)?
/Mats
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 06:30 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 00:10 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 12:11 -
VIDEO_TS to DivX Ultra
By spidey in forum Video ConversionReplies: 14Last Post: 26th Mar 2008, 03:05 -
VLC - plays DVD from video_ts folder?
By qpskfec in forum Software PlayingReplies: 9Last Post: 21st Nov 2007, 13:38
