  1. I'm looking for a piece of webcam software that is pretty advanced. It needs to have a lot of settings on picture and video formats/resolution/bitrate etc.
    I've already tried Watcher and WebcamXP Pro 2007 but they were too simple.
    Do you have any recommendations? Please don't mention WMM.
    Maybe it will work with a capturing tool like iuVCR
  3. Forgot to mention that I'm using Vista. Installation failed.
    Other recommendations?
  4. Mod Neophyte redwudz's Avatar
    USA
    Did you use 'Run as administrator' to install? If that fails, I would also try 'Compatibility mode'. That's in a R click menu in 'Properties' when you select the program installer. 'Windows XP (Service Pack 2)' mode may work.
