hi folks, just wondering if i get get a little help with a small problem,
I use winavi (latest verson) to convert my avi to dvd and i use nero (latest verson) to burn my dvd's b4 i was able to burn and say a film/dvd had 3 chapters on in well i could have watched the film in one go after 30mins it would have paused for a second and then continued, now it stops and gos back to the main menu and i have to manually click on the next part of the film. any help on how to sort this out would be appricated. i dont know if its winavi or nero![]()
Sorry to break it to you, but WinAVI is rubbish. Low quality, unstable and unpredictable. Uninstall it first, and create DVDs with something else. ConvertxtoDVD is a better option if you are happy to pay. FAVC is a great freeware option if you need basic menus, DVD Flick if you don't.
If you downloaded a movie in three files then use DVD Flick and it will join them into a single title, instead of three separate titles.
Finally, burn to disc with Imgburn (free) in build mode.Read my blog here.
OK.. maybe you can assist me with this because i don't quite get it.
I spent literally 5-6 hours tonight trying to figure out why i could only fit 2 episodes of dexter on a video dvd, i have 11, season 1, and i want it on dvd.
Nero wanted to reduce the quality and make it unbearable to watch.
So then i just said screw it, burned all 11 episodes (350mb avi files each) to a dvd as data.
I put it into my dvd player (toshiba)
and it plays, absolutely perfectly, flawlessly, perfect sound, perfect video.
Granted, i have no fancy menu
But if i hit next, it goes to the next episode
Why oh why would i need to waste my time and money converting these to be on a video dvd when a data dvd plays them flawlessly. -
Not all DVD players will play back Divx/Xvid encoded files. Many still only play DVD Video discs, in which case the files must be converted. That said, you should have been able to get 3 episodes on a disc at the same quality as the originals (which are far from DVD quality to begin with) without any effort, if you use the right tools.
Read my blog here.
Making an audio CD on Nero
By orfajackson in forum Newbie / General discussionsReplies: 5Last Post: 12th Apr 2009, 16:03 -
Help with making menues with Nero 8 (Vision 5)!
By Ikka in forum Newbie / General discussionsReplies: 0Last Post: 3rd Feb 2008, 10:24 -
Nero 6 and Making a Photo CD
By solarblast in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2007, 11:56 -
Nero 7 is making movies bigger than they should be...
By Harkonnen in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 01:59 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18
