OK i downloaded a Tutorial for a software and i notice that it was in mov and the file size was small and the quality was good and i wanted to do that but i don't know how i converted a wmv to mov using Sorenson 3 codec but the file i huge and there file isn't ..
Heres The Info Of The File:
Format : QuickTime
Format/Info : Quictime movie
Format/Family : MPEG-4
File size : 5.49 MiB
PlayTime : 3mn 32s
Bit rate : 216 Kbps
Encoded date : UTC 2007-06-29 16:45:08
Tagged date : UTC 2007-06-29 16:45:08
Video #0
Codec : Sorenson 3
Codec/Info : Sorenson Media Video 3 (Apple QuickTime 5)
PlayTime : 3mn 32s
Bit rate : 152 Kbps
Width : 880 pixels
Height : 660 pixels
Display Aspect ratio : 4/3
Frame rate : 4.999 fps
Minimum frame rate : 4.225 fps
Maximum frame rate : 5.000 fps
StreamSize : 3.86 MiB
Encoded date : UTC 2007-06-29 02:15:48
Video #1
Codec : png
PlayTime : 66ms
Bit rate : 929 Kbps
Width : 880 pixels
Height : 660 pixels
Frame rate : 15.000 fps
StreamSize : 7.49 KiB
Encoded date : UTC 2007-06-29 16:45:07
Audio #0
Codec : MPEG-1/2 L3
Codec/Family : MPEG-1
Codec/Info : MPEG-1 or 2 layer 3
PlayTime : 3mn 32s
Bit rate : 353 Kbps
Channel(s) : 1 channel
Resolution : 16 bits
StreamSize : 8.94 MiB
Encoded date : UTC 2007-06-29 02:18:36
Use a better compression and a lower video bitrate for smaller file size, for example h264 video. I use Mpeg StreamClip to make mov with h264.
what is a good bitrate u recommended ..? and how would i be able to change it with that program..
Edit: When I Export To what ever i want it doesn't show the video i shows all black ... -
Compare the specs of the original file with yours (resolution, bit rate, etc.) Some software allows you to make changes and others don't.
There are many different video formats that you can use. The decision is usually based on the final use of the file.Google is your Friend
.MOV conversion to .AVI and .MOV HD quality query
By Peewitisland in forum Newbie / General discussionsReplies: 3Last Post: 31st May 2011, 11:22 -
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 15:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
.mov help!!!
By leftykonashred in forum EditingReplies: 4Last Post: 25th Oct 2009, 04:31 -
MOV to MOV?
By darogo in forum ffmpegX general discussionReplies: 2Last Post: 15th May 2008, 02:08
