I bought a Vizio 50" plasma HDTV at Costco on black Friday for $999. I am going to upgrade my Dish Satellite service to HDTV. Is there any difference in quality between the HDMI output and coax from the HDTV satellite receiver? I want to use the HDMI inputs on the TV for other devices and use the DTV coax input for the satellite box.
For HD you must use HDMI. The current Dish boxes probably require the TV to be HDCP compliant as well. A new Vizio will be.Originally Posted by SCDVD
That machine has 3 HDMI inputs. What are you using them all for?
Mine is a VP50 a model from earlier this year which only has two HDMI ports. I want to attach a player and a Netgear EVA8000 to the HDMI ports.Originally Posted by oldandinthe way
If you need more hdmi connections....
http://www.monoprice.com/products/search.asp?keyword=hdmi+switch&x=0&y=0
I use the manual 2x1 for my single HDMI plasma to home theatre and to my HD A2 player,works great...
" Who needs Google, my wife knows everything"
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Component or HDMI to Coax - USB TV Tuner
By Somebody2 in forum DVB / IPTVReplies: 5Last Post: 27th Dec 2010, 23:46 -
VGA versus HDMI comparison article wanted to explain the difference
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2009, 09:55 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51
