    Feb 2005
    Bollywood
    I've setup a capture system using an old handycam to capture movies/shows from our Foxtel unit. I had to cut and strip an S-Video cable and terminate 2 of the wires with a 75 ohm resistor and used it with a Scart-to-S-Video adapter to feed AV into the camera's line inputs. Without the custom cable, the colours looked totally wrong. No way am I going to record using Composite!
    A firewire cable connects the camera to a laptop so I can record the DV stream straight to a hard disk.
    What I am unsure of is if I have to do any levels correction. I don't know if my captured DV AVI footage uses luminance levels of 0-255 or 16-235. I've encoded the movie twice: Once with no levels correction and once with the AVISynth line
    ColorYUV(levels="TV->PC")
    . I just need you to look at some screenshots and tell me which looks more correct. I chose to capture a well-known movie so you can easily tell as if the colours and levels look wrong.
    I had a comment from my brother that the movie had a different feel so there must be something wrong with the colours or luminance levels. He likes the darker movie as it hid the blocky artefacts more but I think there is less detail.
    Maybe also, I've just stuffed up the custom cable I made. I couldn't find a 75 ohm resistor so I chained 3 of them to roughly make up 75 Ohm but I don't think it would matter if I am off +- 5 ohms, would it?
    Anyway just check these screens and make some comments.
  2. Hi-
    I can't answer your main question, but:
    Just add:
    ColorYUV(Analyze=True)
    to a basic unfiltered script, open it in VDub, and scroll around. Check the Luma Y min and max values. My guess is that 0-255 is being used.
    Feb 2005
    Bollywood
    Yes you are right. Min values reached 0 and Max values reached 255 occasionally so that means my capture is already in the PC scale and I don't need to use ColorYUV(levels="TV->PC") when converting to Xvid or when importing into CCE.
    When I used ColorYUV(levels="TV->PC"), the Min/Max values were reached too often so blacks were deeper black at the cost of shadow detail and contrast increased too much.
    Feb 2006
    Canada
    the videos on the left had crushed blacks.
    Therefore, I conclude the capture on the right is the correct ones.
