I just bought a HP dvd1040i to replace my older and slower drive, but for some reason I am having trouble backing up dvd's with it. I am using the newest version of dvdfab decrypter and dvdshrink. When dvdshrink gets to the burn stage, it burns until it gets to about 2-3% (just enough to ruin the disk) and then gives me a long error message (below). I am burning on Memorex dvd+r's, and I have already tried reducing the write speed to 12x (drive will burn dvd+r's at 20x, disk's max speed is 16x) to no avail. The drive reads and writes cd-r's and reads dvd's just fine, but when it comes to writing dvd's it just doesn't work. Any suggestions? Thanks in advance.
xxxx-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero API version: 7.2.3.3
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Nero\Nero 7\Core\
Application: ahead\Nero - Burning Rom
Internal Version: 7, 2, 3, 3
Recorder: <HP DVD Writer 1040d> Version: EH23 - HA 1 TA 0 - 7.2.3.3
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y160M0 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HP DVD Writer 1040d atapi Port 3 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8162B atapi Port 3 ID 1 DMA: On
=== CDRom-Device-Map ===
HP DVD Writer 1040d H: CDRom0
HL-DT-ST DVD-ROM GDR8162B I: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1534MB (1571564kB)
Free physical memory: 729MB (746700kB)
Memory in use : 52 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.11.2007
NeroAPI
3:03:19 PM #1 Phase 112 File APIProgress.cpp, Line 278
DVD-Video files reallocation started
3:03:19 PM #2 Phase 114 File APIProgress.cpp, Line 278
DVD-Video files reallocation completed (no file modified)
3:03:19 PM #3 Phase 111 File APIProgress.cpp, Line 278
DVD-Video files sorted
3:03:19 PM #4 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
3:03:19 PM #5 Text 0 File Reader.cpp, Line 124
Reader running
3:03:19 PM #6 Text 0 File Writer.cpp, Line 113
Writer H: HP DVD Writer 1040d running
3:03:19 PM #7 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
3:03:19 PM #8 ISO9660GEN -11 File Geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
3:03:19 PM #9 ISO9660GEN -11 File Geniso.cpp, Line 3312
3:03:19 PM #10 Text 0 File Burncd.cpp, Line 3400
Turn on Disc-At-Once, using DVD media
3:03:19 PM #11 Text 0 File DlgWaitCD.cpp, Line 290
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2240383 (497:51.58, 4375MB)
3:03:19 PM #12 Text 0 File DlgWaitCD.cpp, Line 302
Write in overburning mode: NO
3:03:19 PM #13 Text 0 File DlgWaitCD.cpp, Line 2733
Recorder: HP DVD Writer 1040d, Media type: DVD+R
Disc Manufacturer ID: RICOHJPN, Media Type ID: R03, Product revision number: 4
Disc Application Code: 0, Extended Information Indicators: 7
3:03:19 PM #14 Text 0 File DlgWaitCD.cpp, Line 474
>>> Protocol of DlgWaitCD activities: <<<
3:03:19 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2240384 (2240384) = #2240384/497:51.59
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2240384 blocks [H: HP DVD Writer 1040d]
3:03:19 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [H: HP DVD Writer 1040d] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4588306432, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2240384 | lead-out | 1 | 0x41 | 0x00
3:03:19 PM #17 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
3:03:19 PM #18 Phase 24 File APIProgress.cpp, Line 278
Caching of files started
3:03:20 PM #19 Text 0 File Burncd.cpp, Line 4231
Cache writing successful.
3:03:20 PM #20 Phase 25 File APIProgress.cpp, Line 278
Caching of files completed
3:03:20 PM #21 Phase 36 File APIProgress.cpp, Line 278
Burn process started at 12x (16,620 KB/s)
3:03:20 PM #22 Text 0 File ThreadedTransferInterface.cpp, Line 2707
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:03:20 PM #23 Text 0 File Cdrdrv.cpp, Line 8995
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Media type ID: R03
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 52 49 43 4F 48 - 4A 50 4E 52 30 33 04 38 ...RICOHJPNR03.8
23 54 37 13 00 44 73 00 - 84 6D 15 15 0B 0B 08 08 #T7..Ds..m......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
3:03:20 PM #24 Text 0 File DVDPlusRW.cpp, Line 650
Start write address at LBA 0
DVD high compatibility mode: Yes
3:04:39 PM #25 SPTI -1135 File SCSIPassThrough.cpp, Line 291
H: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x00cd0000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3:04:39 PM #26 CDR -1135 File Writer.cpp, Line 302
Write error
3:04:39 PM #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
3:04:39 PM #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
3:04:39 PM #29 Phase 127 File APIProgress.cpp, Line 278
Generating DVD high compatibility borders
3:04:39 PM #30 Phase 129 File APIProgress.cpp, Line 278
Generating DVD borders completed successfully
3:04:39 PM #31 Phase 38 File APIProgress.cpp, Line 278
Burn process failed at 12x (16,620 KB/s)
3:04:39 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
3:04:39 PM #33 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Remove your NERO SERIAL NUMBER from your NERO log that you posted.
Use better quality dvd media like VERBATIM. MEMOREX is considered crappy dvd media.
When using DVD SHRINK disable the feature that allows using NERO to burn automatically. Instead use IMGBURN to burn your dvd media.
I doubt your new dvd writer is causing the failed burns since you're using crappy MEMOREX dvd media. -
Thanks, it worked! BTW, are Sony DVD+R's considered crap too? I have a spindle of 100 of them for when I run out of Memorex...
What worked for you? Using SONY DVD+R media or using IMGBURN to burn after using DVD SHRINK?Originally Posted by carstd01
In my experience w/SONY DVD media it can be hit or miss since they now manufacture their own dvd media. I've had some discs in a spindle of 50 & 100 spindles only be able to burn at 4x speed. When SONY used to have TAIYO YUDEN manufacture their dvd media it was great with no problems at all. But now they manufacture their own dvd media and it's not the greatest. I'm sure others will post they've had no problems with it. VERBATIM & TAIYO YUDEN are good quality dvd media to use. That's the only brands I'll use for backing up my dvd movie collection.
I just used ImgBurn after encoding with DvdShrink. I'm not sure why it worked, as the DvdShrink/Nero combination always worked with my other drive, but it did. I still used the Memorex disks, but it still only works at 12x; 16x still seems to ruin disks. The Sony disks are unopened, so I will probably exchange them for some better quality media. Thanks again!
It worked because your new drive is too new for the old programs to have the drivers for it, could be the same about your media.
There's no need for any new drivers when using a new dvd burner. I've never had a problem when using a new dvd burner. I have over 20 dvd burners which never had a problem after installing into any pc. NERO software is and has been buggy to begin with which is why I suggested using IMGBURN.Originally Posted by handyguy
dvd writer help
By Stephb in forum DVD RippingReplies: 2Last Post: 2nd Feb 2009, 15:38 -
dvd / cd writer
By bill gailer in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jan 2009, 21:18 -
After a new DVD Writer..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 10:01 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 00:08 -
dvd writer problems
By ellabbs in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2007, 16:05
