I have a concert in DVD-format on my hard drive that was recorded from a satellite broadcast by a friend of mine.
But whenever I try to burn it with Nero or open it with other authoring programs I get an error regarding the IFO file.
I can watch the VOBs just fine with PowerDVD or VLC but how do I fix that IFO so I can burn it as a normal DVD?
It depends what is wrong with it.
Also, don't burn with authoring tools. Try Imgburn instead.
Simplest test is to delete the IFO, and copy the BUP file with the same name, changing the extension from BUP to IFO. If this still fails, copy the VOBs to another folder, then use IFOEdit to create new IFO files.Read my blog here.
how to fix broken avi seeking?
By muffinman123 in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2011, 17:40 -
trying to edit dvd get VTS_18_0.IFO contains bogus data error, FIX?
By Denvers Dawgs in forum Authoring (DVD)Replies: 6Last Post: 2nd Apr 2011, 16:45 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 12:04 -
How can i remove/fix some broken codecs?
By GangstaRap in forum Newbie / General discussionsReplies: 23Last Post: 23rd Feb 2008, 04:04 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 07:56
