I just bought a Kodak easyshare that takes 16X9 high def video using mp4 compression. How to I convert this to an mp4 file that my new dvd recorder/player, (that says it is mp4 compatible) will play?
I did one long video with it, its about 400 meg in size, but when playing it back on my laptop in gets CPU bound and skips like crazy, even copying it to CD and playing on a more powerful machine does this. I thought if I can convert it to a format that will play in my dvd player it may play better.
thanks
What video and audio codec does the kodak record in? Because mp4 is no video codec. Identify the video and audio codec in the mov with mediainfo.
And I guess your dvd player only supports divx/xvid sd video(no High definition), so I would try convert to avi xvid alltoavi. You can also try convert the mov to avi xvid with Mpeg StreamCLip.
And if the mov contain HD h264 video you need a fast computer to play it smooth, use haali media splitter together with LATEST ffdshow and play in MPC. Or use CoreAVC instead of ffdshow, it's the fastest h264 decoder but it's not free then.
DVD Player that plays Divx (.avi) and (.mp4) files ?
By keith knip in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 14:12 -
burning divx files as data to play on dvd player
By penguyen in forum Authoring (DVD)Replies: 4Last Post: 30th Jul 2011, 10:54 -
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
Any DVD player that will play divx files larger then 2GB?
By David9799 in forum DVD & Blu-ray PlayersReplies: 27Last Post: 9th Nov 2007, 10:53 -
can i play mp4 format files on my dvd player
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 05:36
