hi,
i have a philips DVD player (DVP1013). The power specifications are given as 120v, 60hz. Can anyone advice on whether this will work with 240 Volts at 50 Hertz electricity. I think the voltage will definitely have to be down converted.... but am not sure if the 50 Hz will be ok.
Thanks....
Venkat,
if u are planning to take to india, converters are available in india which will bring down the voltage and also the 60hz factor, i used the same for cyberhome dvd player, but didnt noticed abt the hz factor.
I have one quesion now,since I bought this philips dvp 1013 in US ,there is no mention which region code this will play,unless assuming that since I bought in US this will support 1 and ALL codes,will this be supported in India where the regopn code is 5.
Thnx -
venkat.naina, are you sure the label on the unit says only 120VAC and 60Hz? That seems unusual. Most electronic devices these days will handle 50 - 60Hz and 80 - 240VAC. The voltage is easy enough to change, but the frequency can be very difficult. To the point that buying a more universal DVD player would be cheaper.
But most all DVD players and quite a few other electronic devices just need a adapter plug. Looking for information on that player seems to show only 120VAC and 60Hz also.
desidc, if it was purchased here in the US, it's probably region 1. If you can find a firmware upgrade, you may be able to change that.
And to both members, welcome to our forums.
thank you for the details on the converter and stuff...it really helped...
actually i do not know about whether it will play region 5 dvds... the steps for making it region free are given in the site but we can never know it works until we take the player there or get one such dvd here
Just use the region hack posted on this website and either select region 5 for india only or select region 0, which is what I do to play all region DVD's....I've played Region 2 and Region 4 along with Region 1 (native country code)disc on this player fine.....
Need to convert to mp4 with these specifications (Philips Gogear Vibe)
By alx1880 in forum Newbie / General discussionsReplies: 20Last Post: 2nd Apr 2014, 21:07 -
Power Supply Question
By jjis in forum ComputerReplies: 10Last Post: 6th Nov 2009, 07:35 -
Philips DVP5992 power light stays on
By glockman305 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Jan 2009, 11:29 -
WinTV-PVR-USB2 MCE-Kit Power supply Specifications help.
By TBoneit in forum Off topicReplies: 4Last Post: 12th May 2008, 09:51 -
question about Power DVD DX
By Bamahusker in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jul 2007, 17:35
