How would I go about adding a second audio over the original dvd audio, and have both play? Most likely either lowering the volume on the dvd audio or upping the volume on the commentary audio. The audio commentary I have is in mp3 form or riff form.
Any ideas. Also free would be great!
What We Do In Life, Echoes In Eternity....
Okay... AFAIK, any second audio track is completely separate from the original. If you want a commentary over the movie sound, you'd need to copy the movie audio to another track and then add your comments over it using an audio editor.
You could author this using DVDAuthorGUI (free) or something similar... any authoring package that supports multiple audio tracks. Freeware audio editors are available... check the TOOLS section on the left.Even a broken clock is right twice a day. -
I use this method in Audacity (1.3.3 beta):
Load the original soundtrack (you may need to convert it to wave).
Load your commentary track too -- now you will see four tracks , L& R for each (unless you have mono).
First check the commentary track. If it seems quiet, boost the volume and/or normalise it.
Now select original soundtrack
You can see the waveform, so zoom in to a louder section of the original.
On Effects menu: choose Compressor.
You want to reduce the volume of loud passages while not changing quiet ones. I use a setting like:
Threshold -29; ratio 10:1
* uncheck "normalise", otherwise the volume will be boosted to compensate for the quieter track.
Then select a few seconds and apply the effect then play it. The commentary track will be audible too (if it's not muted). If it seems okay -- commentary audible and original not too quiet, then undo and select all, apply the effect to the entire track.
Play it again. If you're happy with it, export the project as WAVE. This will mix it in. Now convert it to AC3, or whatever (ffmpeg, BeSweet, etc).
I've done this to add podcast commentary tracks to TV episode compilations.
In most DVD authoring apps you can add alternate soundtracks, I generally label these commentary tracks as "German" lacking any better tag, just so I know which is which.
Use DVD Fab to capture audio commentary rather than straight film dialog
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 20th Aug 2011, 12:26 -
MPEG Streamclip:DVD is ripped with commentary audio stream
By camilla89 in forum DVD RippingReplies: 0Last Post: 29th Aug 2010, 10:43 -
How can I add an audio commentary to a dvd?
By artyjeffrey in forum Authoring (DVD)Replies: 1Last Post: 28th Nov 2009, 04:44 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
Add a commentary track to A DVD
By R3bel in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 09:42
