I have a Philips SA6045 MP3 player, which also plays WMV video files. According to the specs, video should be 384kb/s, and up to 30fps - audio should be 44.1. The player comes with it's own converter which works fine, but I would like to use WinAVI to get some more options. When I try to use what I think are the proper settings, the file will not play on the player. I know this is vague, but any ideas? I'm including a screen cap from Gspot of a file converted with the bundled software. This file DOES work.[/img]
	ok, here are two new screenshots. the one on the right is a file created with the bundled software, and the one on the right was created with DVDFAB Platinum. specs are identical as far as i can tell, yet the DVDFAB file gives me an "unsupported file type" error when i try to play in on my player. this is frustrating!
	Originally Posted by revlis
 Just an observation, but in the 1st picture audio is 44KHz.
 In the 2nd picture, the left audio 48Khz, the right is 44KHz...But you mentioned "right" twice :P I'm not sure which is the working one
	Well I don't know about the name change but if those are new screen shots poisondeathray is right, one shows 48khz and the other is 44.1khz. If your player specs 44.1 khz than you should reauthor the file to 44.1khz with the other specs being the same. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  What should I convert WMV to?By videohalp in forum Video ConversionReplies: 3Last Post: 1st May 2009, 17:06
  Cant convert to WMVBy batmax in forum Video ConversionReplies: 4Last Post: 11th Sep 2008, 02:17
  PVP recommendations for my specific needsBy ZAP in forum Portable VideoReplies: 3Last Post: 28th Sep 2007, 21:28
  I need too convert TOO wmv from aviBy theewizard in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2007, 20:59
  How to convert wmv clip so its properties match other wmv clipsBy sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
