I am using Power Director 6 for the first time. No problem editing my movies but when I create an AVI file from my project, there is no audio during playback with either Real Player or Windows Media Player. Can anyone help?
Thanks.
Drop the file into Gspot and see what it lists for the audio format. Gspot should also tell you are missing a playback codec. MP3 and AC3 are commonly used for AVI type files. MP3 is more common. Other formats like Ogg are also used to a lessor extent.
To playback AC3, you may have to install a codec, like AC3 Filter. VLC should play them without any codecs and it's one way to test if you have a codec problem.
And welcome to our forums. -
You could post a Gspot screenshot here, or have you tried using VLC to play one of the files? Neither Real Player or WMP are very good players, IMO.
For posting Gspot screenshots: https://forum.videohelp.com/topic271697.html
Some common possibilities are the audio is out of spec or wrong for your format or you don't have the proper tools to play it back. For example MP3 audio won't work with MPEGs most times and MPEG-1 Layer2 audio won't work with AVIs most times.
Help burning Pinnacle project to DVD...mpg, converting, etc.
By jubbilee in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2011, 14:37 -
Converting a 4:3 project for a 16x9 HDTV
By jeffgrooves in forum Video ConversionReplies: 2Last Post: 24th Aug 2010, 13:25 -
Converting AVI Audio Bitrate
By RayArt in forum Video ConversionReplies: 3Last Post: 13th Sep 2009, 08:33 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
