I have made audio compilations for years and am interested in doing same with my commercially made concert DVDs, but with full video and audio without any loss in quality. I have been doing research and understand that I copy to my hard drive and then export to a DVD burner and that I need 2 software packages- a dycrypter and an editing package. I must admit that its confusing and would appreciate any help in suggesting the right combination of software that would give me quality as well as the editing tools to make sure I can do a smooth transition from song t song. Thanks
For editing and final DVD try Mpeg Video Wizard DVD.
You have to rip DVD first as you already know than import to Wizard and edit. This package is for mpeg editing and it will not re encode files if DVD compliant, only transaction or modification you make.
You can put a few video songs from different DVD to one -
Tinker
thanks for the advice; a couple of questions: will MPEG Video Wizard DVD keep the original audio format eg. 5.1 or stereo? any idea how much recording time is available in a DVD-R? assuming the average song is 4 minutes, how many do you estimate I can record on a disk?
regards
Paul -
Video Wizard does not re encode compliant file only the modifications to it.
If your original sound is 5.1 it will stay that way. Mind you you cannot mix stereo and 5.1 in one title on DVD.
As for recording length it depends on your file bitrate (audio+video) and time, should be about 2 hours, but you can use bitrate calculator to figure your situation.
https://www.videohelp.com/tools/VideoHelp_Bitrate_calculator
Burned multi-title compilations will not play on any of my 3 standalone DVD
By Yanta in forum Authoring (DVD)Replies: 7Last Post: 17th Apr 2012, 17:35 -
looking for software to help edit and make compilations
By rockerman in forum AudioReplies: 7Last Post: 26th Apr 2011, 00:56 -
Need help with DTS Audio recognition in AVCHD compilations.
By jay-t in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Jun 2010, 11:20 -
All Nero compilations expires after 1 burn?
By Blå_Mocka in forum ComputerReplies: 7Last Post: 14th May 2008, 12:17 -
mp4 compilations?
By drwho in forum EditingReplies: 2Last Post: 24th Mar 2008, 20:00
