I have a Dell 20.1 inch LCD Monitor 20" Monitor (2000FP) and it did not come with the power cord.
It is not the typicall power cord that crt monitors use, it is more like a power supply box with a cord
that plugs into the outlet and another cord coming from a box into the monitor.
My question is, is there a place taht they make a universal power cord for this monitor or do i need to by a specific one from Dell.
As always that for your time and effort
"Do or Do not, there is no try"- Yoda
http://cgi.ebay.com/19V-AC-power-adapter-for-Dell-2000FP-20-LCD-monitor_W0QQitemZ18018...QQcmdZViewItem
7K713 or 5W440 ???
Both are listed. Both LOOK LIKE the same adapter. If you have the manual, Google the PN.
I've used Vance Baldwin in the past for hard to find parts; didn't see this adapter.
You may want to read this forum:
http://www.dellcommunity.com/supportforums/board/message?board.id=dim_monitor&thread.i...cending&page=1
The one listed on ebay (first link) is the lowest price that I found - and has the round plug at the monitor end. I would look into the Dell recall on that power supply were it mine.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
thanks for the speedy reponse.
i will look into those links."Do or Do not, there is no try"- Yoda
In search of the right power cord for my Panasonic Color Monitors BT-S702N
By Silverage in forum Newbie / General discussionsReplies: 12Last Post: 1st Mar 2024, 18:15 -
ADVC-500 Replacement AC Power Adapter
By mjermine in forum Capturing and VCRReplies: 2Last Post: 5th Dec 2010, 18:53 -
Which to use on a Laptop, the Battery or Power Cord
By Moontrash in forum ComputerReplies: 4Last Post: 7th Jun 2010, 19:16 -
VirtualDub Won't Let Monitor Power Off - Any Solution?
By Chakra in forum Newbie / General discussionsReplies: 9Last Post: 12th Oct 2008, 19:06 -
Computer Monitor Won't Power Up
By StrengthFTW in forum Newbie / General discussionsReplies: 4Last Post: 24th Nov 2007, 11:08
