    Nov 2007
    Germany
    I have 32732ms delay Ac3 file,when i input this file in MeGUI,MeGUI not accecpt.
    Bcos MeGUI Accecpt only 10000ms delay files.
    How to Increase MeGUI ms delay option.
    See the picture
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Maybe extract the audio, remove the delay, then remux and import into MeGui.
    Google is your Friend
  3. usually so large delay are due to corrupted timestamp in vob
    using dgindex, skip the first gops using the > , and save the d2v
    you can also use the analyse synch tool
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
