I record programs from TV in mpg format and convert then for my personal use to DVD. I find a low underlying hum in the audio track that i would like to remove using some audio filter. My video editing software does not have an audio filter that can do tis - so i would like to know how best this can be done without compromising on the the quality of the video.
Have i to strip the audio from the video track and then multiplex it again on the video editor timeline
Any recommended software that can do this EASILY
In other words i would like to reduce the slight hum in the background of my captured video
Thanks for any help on this issue
I've found the latest version of Audacity (1.3.3 beta)'s noise filters much improved on earlier versions.
Also you might try a notch filter for a simple hum (reduces a single frequency band).
See http://audacityteam.org/wiki/index.php?title=Noise_Removal for details on both methods.
Yes, you do have to demux the audio, convert to wave, edit in Audacity, then export back to wave and convert back to AC3 or whatever and remux.
The video will be unaffected.
Otherwise, you might look at ways of reducing the hum to begin with. Perhaps some earthing or better shielded cables. -
I use Goldwave. You need short segment (e.g., 1 to 3-seconds) of the hum only (i.e., no other audio). Goldwave has a filter that will subtract that noise from the entire audio track. Goldwave only works on wave so you'll have to convert your DVD audio (likely ac3 or mpeg) to wav first. Edit it. Then covert it back to ac3 or mpeg.
Audio hum during video capture...help.
By daysaf00 in forum Capturing and VCRReplies: 16Last Post: 27th Jan 2012, 21:04 -
How do I remove/repair AVI video file virus?
By paulywalnuts in forum Newbie / General discussionsReplies: 6Last Post: 7th Feb 2011, 21:40 -
remove some text on avi video file
By SB4 in forum EditingReplies: 6Last Post: 30th Jan 2009, 07:30 -
How do u remove video security or DRM from a vid file?
By jones24 in forum Newbie / General discussionsReplies: 8Last Post: 3rd Nov 2008, 14:05 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
