I have tried some free trial version tools to convert the video file format but none of them gave me the option to conver WMV to AVI or MPEG. Is there any other way to convert WMV? I searched but didn't find what I needed. So I am seeking your help. Thanks!
SUPER or WinAVI are two simple ways. If you want more control and quality, then it's not so simple. TMPGEnc encoder can do some WMV formats. Or you could use Windows Movie Maker and output as DV AVI, then convert that to a different format, such as Xvid or other AVI type formats. Or use a MPEG encoder if you want a MPEG-2 DVD type format. Many other ways also.
And welcome to our forums. -
The most reliable way for me to avoid sync issues has been to drag and drop the WMV file into TMPGEnc and save as MPEG.
With the new version of Virtualdub (either 1.7.6 or the experimental 1.7.X_test6)
http://sourceforge.net/project/downloading.php?groupname=virtualdub&filename=VirtualDu...irror=internap
http://www.virtualdub.org/beta/VirtualDub-1.7.X-test6.zip
and the WMV plugin
http://fcchandler.home.comcast.net/Plugins/WMV/
You can now import WMV into Virtualdub and convert most files to AVI without sync issues. I have found that there are still some files that will not convert without sync issues. Most WMV files are variable frame rate which can cause problems. -
Or virtualdub-mpeg2, built in WMV support.
Convert mpeg-2 to wmv
By king71 in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 03:26 -
Any software to convert WMV to MPEG? Thanks for helping.
By seymoria in forum Video ConversionReplies: 2Last Post: 18th Apr 2009, 09:18 -
What's the best software to convert Mp4 to WMV/MPEG ?
By billyww in forum Video Streaming DownloadingReplies: 3Last Post: 10th Jan 2009, 17:15 -
convert wmv to mpeg for PS3 - Requesting expert advice again :)
By RS4 in forum Video ConversionReplies: 5Last Post: 14th Aug 2008, 19:00 -
Convert mpeg-4 to wmv with super
By Kalash109 in forum DVD RippingReplies: 2Last Post: 17th Nov 2007, 06:14
