I could find any got topic for this so i try to explain instead
How shall i do if i wanna create a video-file out of a audio file, with just a black picture with sound
guess the sourche question involves just how to create a video file, choose it's extension, and then last add the audio-file to it.
I tryed on my own with extremley skill to fool the Mp3 by just rename the extension to AVI..it worked as far as the eye could see atleast, but the editing programs didnt agree
/Blå Mocka
Use Windows Movie Maker and put your mp3 on the audio track. Leave the video empty and create the movie. You only have the choice of DV AVI or WMV, though. For the DV AVI option, the audio will be similar to PCM (i.e., wav).
Alternatively, find a tool that can convert mp3 to wav and then import that into your editor. -
I'm sure there are better ways, but using VirtualDub or VD Mod, I just take a existing video of the right type and length (Or trim it) and use the grayscale filter to lose the color if it's there, then set the brightness/contrast filters at zero, disable the existing audio and save it out with the new audio file added. That way the sync, codec and indexing is set properly.
In TMPGEnc Plus, choose a picture file for video source,
your .mp3 for audio source, adjust the other settings,
click "Start". ^_^
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12 -
Merging audio file and video file using ffmpeg
By suresh3484 in forum ffmpegX general discussionReplies: 0Last Post: 27th May 2008, 03:05 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 00:15 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
