I am having no luck playing my SVCD after burning using Nero. The MPG files work fine when I play them on the hard disk. I've used the Compaq DVD player and WinDVD software players. I have also followed the procedure for making the SVCD from the http://www.dvdripguides.com site. Is there any way I can resolve this problem?
<font size=-1>[ This Message was edited by: sporty45 on 2001-07-21 22:43:38 ]</font>
You said that you had no success in playing your burnt SVCD disks. Have you tried them on your standalone DVD Player? Is your player compatible for the media type you are using? (Checkout the DVD Players compatibility list). If you're testing the disk on your pc, make sure you have the software (mpeg2/DVD Software player) installed.
too big when burning with nero
By chief-1 in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 21:21 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 22:04 -
Nero burning DVDs from the outside in?
By 2prfm.com in forum Authoring (DVD)Replies: 12Last Post: 19th Jun 2008, 21:47 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35
