Hey guys
i encoded a file using tmpgenc
i only did an elementary stream for video because the source audio was 5 ch ac3
so i demuxed the audio using vdubmod
and now when i try to add the demuxed audio to my encoded video file on tmpgenc dvd author when im ready to author the files.. it says that its an illegal audio format, that standalone dvds can only have mp2 ac3 or pcm audio. im like 'helllooo' this IS ac3,
kinda stupid, but i dunno.
it just wont work.
any one know how to fix this?
i can resort to extractingit as a wav and converting it to AC3 again but that would mean i would have to put 2 addition convertions on the audio which may damage its quality a bit.
i tried to put the extracted AC3 through belight but tht wont work, it finishes in like a second, and produces a 0kb filethat doesnt work.
i tried to extract the audio and save it as a wav. i did a direct stream copy and saved as wav using vdubmod, i put it through belight, and it just does nothing, i left it for 10 mins, no change not even any ETA.
anybody know how to solve this?
i would prefer to have it demuxed frst time and put it straight into my dvd authoring programme
thanks,
Mubs
Results 1 to 12 of 12
thanks for speedy reply,
i downloaded that little app,
but it does nothing,
is there any guide for this?
regards,
Mubs -
Pretty simple to use. Put it in your windows/system32 dir.
Open a command prompt, change to the dir of your AC3 file.
type
(replace original.ac3 with the real name of your ac3 file of course)Code:ac3fix original.ac3 fixed.ac3
That's it!
/Mats -
hehe sorry noob here,Originally Posted by mats.hogberg
how do i change the directory,
all i know is that the file is in the d drive. -
Well, I really can't teach you how to use a computer, but you change directory by typing cd followed by the directory name, like cd temp
You change drive by typing just the drive letter folowed by :, like d:
You can also skip the part of changing directories by specifying the full path to your input and output files, and run ac3fix with for example:Beware of spaces in the folder/file names tho - If you have, it may work if you surround the path with quotations, like:Code:ac3fix d:\rip\audio\original.ac3 d:\rip\audio\fixed.ac3
but then again it may not. Allowing spaces in folder/file names was never a good idea.Code:ac3fix "d:\rip\audio files\original audio.ac3" "d:\rip\audio files\fixed audio.ac3"
/Mats -
Originally Posted by Midzuki
To the more helpful mats.hogberg - Thank you very much,
your help is much appreciated,
regards,
Mubs -
@ the OP:
Should I really have added "press the ENTER key after writing
'help' on the command-line window"
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
Source image format is not acceptable (VDMOD, XVID, AC3)
By stlolth in forum Video ConversionReplies: 8Last Post: 23rd Aug 2010, 11:22 -
AC3 doesn't work after format
By Xavier in forum AudioReplies: 7Last Post: 26th Feb 2009, 19:27 -
rip AC3 track without format change
By shun in forum DVD RippingReplies: 2Last Post: 9th Feb 2008, 04:01 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54
that doesnt work.
