Hello all,
I just messed up a second disc trying to burn a film to DVD. The error log message was as follows:
========== BEGIN OF LOG ==========
Examples SDK_DATACD
Start Time: Thursday, November 22, 2007, 11:12:45AM
Processor Architecture: INTEL
Processor Type: INTEL PENTIUM
Processor Level: 15
Microsoft Windows XP version 5.1 Service Pack 2 (Build 2600)
Memory in use: 83%
Total physical memory: 457 MB
Total free physical memory: 74 MB
Total paging file: 1079 MB
Total free paging file: 753 MB
Total virtual memory: 2097 MB
Total free virtual memory: 1984 MB
CD Layout: Data DVD
Disc Format: DVD-ROM
File System: UDF
Bootable CD: No
Total Data Blocks: 1822176
CD-Recorder: Slimtype DVDRW SOSW-833S (E
Firmware Version: VRS2
Disc Media: DVD+R
Free Disc Blocks: 2295104
Test: No
Write Speed: 4x
Write Method: Disc-At-Once
Close Disc: Yes
Leave Session Open: No
Error Code: 1014
CDB: 2A 00 00 00 00 00 00 00 20 00 00 00
SenseKey:03 ASC:73 ASCQ:03
Finish Time: Thursday, November 22, 2007, 11:14:05AM
========== END OF LOG ==========
If anyone could tell me what the specific problem is that has caused the error I would be grateful.
cheers
If you told us which authoring/burning application, DVD writer, blank media you were using and type of movie file you were trying to burn, that might help? We're not all psychic you know
Per Microsoft: (Googled Error Code 1014)
CdoE_NOT_ENOUGH_MEMORY
&H8007000E
1014
http://msdn2.microsoft.com/en-us/library/ms526879.aspx;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Hello,
I was using NTI Maker 7, a slimtype DVDRW SOSW-8335 (VR52), Kodak DVD-Rs and the file is an MPEG-2; though I don't think any of those things are the problem.
The 1014 (not enough memory) is probably the issue then, so I guess I'll have to delete some things off my hard drive or something.
cheers for the info
Unable to install avisynth: Error opening file for writing
By ximon in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2011, 17:52 -
DVD Architect Pro 5.2 error writing file?
By dabezt in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Aug 2011, 07:55 -
ShowBiz DVD 2 Error - Failure writing the disc
By smbcingu in forum Authoring (DVD)Replies: 4Last Post: 2nd Jan 2011, 16:34 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 10:47 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 07:28
