This might be a newbie question, but with the DL-DS DVD's, when recording, do you have to stop the recorder half way through the discs capacity and turn the disc over?
	These are called DVD-18? Another query, I can't see any listed when I searched in DVD Media. Are they perhaps pro-use only?
	They don't make double-sided DL media. Want my help? Ask here! (not via PM!)
 FAQs: Best Blank Discs  Best TBCs  Best VCRs for capture  Restore VHS
	That is in DVDR format.Originally Posted by lordsmurf
 You can commercially press a double-sided DL disk. Many of them are out there usually with 4:3 aspect ratio on one side and wide letterboxed 16:9 on the other.
	Don't know if they make those in burnable DL or SL but all the flippers I've seen like that locally are rental and Public Library lenders in SL format with 4:3 on one side and widescreen on the other. None of my pressed bought DL discs are flippers even when they are multi disc packs nor have I seen burnable flipper DL or SL blanks here in the great white north.Originally Posted by edDV
 Even if burnable SL or DL flippers would be available, I suspect the burner apps are written in such a way that they expect a complete burn on each side. So it's like burning 2 separate video discs and you look after the authoring. If you wanted one long video across 2 discs then after part1 insert a small end video menu that says something like " End of part1, flip the disc to continue" then on disc 2 you could just have a video with either a simple menu entitled part 2 or no menu and just start the video. In any case you would still be doing 2 separate burns.
	A Quote
 The DVD sizes can be a bit confusing. There are basicly 4 different DVD Sizes,
 DVD-5, holds around 4 700 000 000 bytes and that is 4.37 computer GB where 1 kbyte is 1024 bytes* . DVD+R/DVD+RW and DVD-R/DVD-RW supports this format. Also called Single Sided Single Layered. This is the most common DVD Media, often called 4.7 GB Media.
 DVD-10, holds around 9 400 000 000 bytes and that is 8.75 computer GB. DVD+R/DVD+RW and DVD-R/DVD-RW supports this format. Also called Double Sided Single Layered.
 DVD-9, holds around 8 540 000 000 bytes and that is 7.95 computer GB. DVD+R supports this format. Also called Single Sided Dual Layered. This media is called DVD-R9, DVD-R DL, DVD+R9, DVD+R DL or 8.5 GB Media.
 DVD-18, holds around 17 080 000 000 bytes and that is 15.9 computer GB. DVD+R supports this format. Also called Double Sided Dual Layered.
 All the Dl disks Ive seen are single sided
 My units will not write to a DL disk but will play a DVD-DL. I dont think a DVD 18 will.
 I believe that most disks on which both sides are used are single layer double side
 If a unit will record to a DL-9 disk, it should not be necessary to turn the disk over although a number of users have reported a glitch when changing layers. I do not know about the DVD-18 . but unless the drive can record/play to BOTH sides (laser top and bottom) it would seem it would have to be turned over
 PS
 Has anyone seen a Blank DL-DS DVD-18 disk,
 As to the original post I believe (lordsmurf is right) they don;t make DL-DS disks (at least at present.
	True. I referred to recordable and/or re-writeable (which do not exist commercially, that I'm aware).Originally Posted by edDV
 Pressed media can and do come dual-layer double-sided. I had one not long ago. A flipper, with 4:3 on one side, 16:9 on the other. Barb Wire, I believe it was.Want my help? Ask here! (not via PM!)
  Double-sided, double-layer. Are they the same thing?By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13
  DVD+R9 Double Layer first burn: problems with layer switchBy Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27
  Double-Sided, Dual-Layer DVD media?By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03
  do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40
  How do I convert double sided dvd to dual layer dvd?By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
